It depends on what type of spacer lift you get. If it's a "pre-loading" spacer then you have to compress the coil and get it in there and then assemble it back together. If it's a top-out spacer, it should and usually does come with extended studs in which you just take the top end off, and replace the studs and fit the spacer in and bolt it back onto your truck.
