Quick repair history rundown – Your thoughts? Is anything missing?
eric_rosenwald
I'm including my full maintenance history for my 3rd Gen 2000 T4R SR5 6-cylinder. I bought it at 175k and it's currently at 250k.
I'm the 3rd owner. It was in nearly flawless condition when I bought it 3.5 years ago. I got extremely lucky to find this one! The previous owners only took it to the dealership for maintenance. It had some rear axle issues a few years ago, and had a few maintenance hiccups early on. However, it's running unusually well for 250k.
I included the full maintenance list since I've been the owner. It's a simple list– I indicated mileage, a list of repairs for the visit and the price. On most of these visits I had the mechanic do a full inspection, too.
I'm not asking for anything specific here. This is a more general question - I'm asking you to tap into your instincts and experience. Is anything missing? Is there an issue that should have been addressed, repaired, inspected, etc.? Does something 'jump out' at you? It's sorted in reverse chronological order.
It's mostly OEM in general, but I did add these:
-4x Billstein 4600s (monotube)
-OME 906 rear coil springs
All 4 shocks and the springs are performing well, even after 60k miles!
Driving background: t's a daily driver, but I also take it 4-wheeling every 2 months. In the summer, I go on a 2,000mi+ road trip that is often loaded down, at high altitudes, with several 5+ mile steep grade runs through mountains. This is in addition to long distance runs on interstates (which noticeably cleans out the engine - it runs much smoother).
Thanks for reading, and thanks for the advice!
9/16/2017:
Repair on tires: LR-screw, RR-nail
ODO 258,232
Free
6/28/2017:
timing belt, water pump, spark plugs & wires, radiator hose
ODO 248,686
1,510
6/16/2017:
resurface front rotors, front brakes, (air speed setting repair: (motor and resistor - 325),
ODO 248,117
12/30/2016:
tie rod end, replace rack & pinion/steering gear
ODO 241,126
1,215
12/2/2016:
tire replacement
ODO 239,104
FREE
9/6/2016:
oil change
ODO 230,410
44
8/3/2016:
new set of 4 Pathfinder Sport tires
ODO 228,832
721
6/24/2016:
tie rod end, wheel bearing assembly, axle shaft seal remove/replace
ODO 220121
807
9/18/2015:
oil change
ODO 213,911
21
9/4/2015:
repaired screw in tire
ODO 213,593
Free
7/28/2015:
install 3 belts
194
7/9/2915:
oil change, air filter
ODO 198,641
56
5/13/2015:
windshield crack repaired
40
4/4/2015:
new front brake pads, overall engine check good. Rear brakes good
ODO
225
3/10/2015:
oil change, replaced right [or left?] front inner tie rod end (previous failed — warranty from 5/31/2015 applies), alignment (free — warranty), new battery
293
11/15/2014:
synthetic oil change/filter, rotate tires, changed spark plugs and wires, fuel injection service, service central 3 step fuel system kit, foaming throttle body cleaner
ODO 187,144
401
9/8/2014:
alignment
ODO 183,496
120
9/8/2014:
rear resurfaced rotors, brake fluid replacement, replaced rear shoes
ODO 183,483
276
9/2/2014:
clean readjust rear brakes
ODO 183,202
90
8/27/2014:
inspection
ODO 182,826
20
7/29/2014:
installed new rear axle bearing/seal, 5k mile oil change
ODO 179,433
526
7/22/2014:
inspection in Modesto
ODO 178,233
50
7/8/2014:
installed 4x Billstein 4600s, OME 906 rear coil springs
ODO 176,601
341 (not counting parts)
6/21/2014:
installed new rack & pinion bushings; inspection: need new shocks (parts/labor est. 815)
20
6/11/2014: installed new rim on 2nd spare (original longtrail a/t)
Free
6/6/2014:
Bought spare tire rim
75
5/31/2014:
fixed left front tie rod end (under warranty)
226
5/30/2014:
suspension check OK
tie rod left front warped — should fix
ODO 174,393
Free
5/28/2014:
4 New Pathfinder sport tires REPLACE AFTER 60k miles
ODO 174,114
725
5/16/2014:
new glass
198
5/12/2014:
purchased
smog check OK
engine check OK
5/16/2014:
tire check OK another 10,000 miles of life
purchased used spare tire
***rotate tires at 176,000mi
Maybe I missed it but did you replace the radiator, water pump, thermostat and radiator cap already? Lower ball joints? Lube driveline? Oh and try not to put 'pathfinder' tires on a 4Runner! LOL.... :cowboy:
I forgot to include that – Yes, the radiator, water pump, cap and thermostat have all been replaced.
I don't recall ever servicing ball joints or lube on the driveline. Should I ask next time I take it in? If so, what should I say?
HAHA yes. I'm going to put Nittos on it next time!
Replace your lower ball joints and find out why you are having so many steering-related issues - how do you warp a tie rod end without trying?
AlaskaRuss
