Quick Wiring question?
SIN-Japan
I am looking to run an ACC wire down to my front Blinker for a Switchback setup, where is the easiest wire to tap into or pull from that is not a always hot wire.
I have searched the forum a bit but have been unable to find the answer, my Google-foo is not strong. :)
1997 Hilux Surf (4 Runner) 5VZFE engine.
Thanks for the Help guys.
If you didnt get this sorted, it might be easiest to do an add a circuit to the acc fuse. Snip a small hole in the firewall boot and run the wire out. It'll be switched power when the ignition is on.
The acc fuse is where I usually wire things that I want hot only when ignition is on. Been doing it for all my vehicles and have never had a problem!
In the engine bay fuse block there is an accy circuit going to the power outlet relay terminal 1. It is fused by the 15A Accy fuse in the driver's side junction block.
On a 2002 it looks like this diagram.
http://tacoma.site40.net/4Runner_96-02_Repair&Wiring/techinfo.toyota.com/ileaf/ewdtmc2/ewdtmpdf/ewdsourc/2002/024runne/relayloc/relayloc.pdf
Look at page 3, it is marked as page 22 of the EWD manual. The lower right corner is where the Power Outlet relay is.
:couch2:
yutaiko
