Radflo 2.5 Installation ?'s
nytefog
Member
Does anyone know of a write up of installing a Radflo kit? I assume its probably the same as the OME setup. I also have the LR upper control arms and heard about squeaking but came across of the installation of bushings and the use of certain hardware and also making sure torque specs are right.
I've had the kit over a year getting all the parts I needed to complete an install with control arms, diff drop, RADFLO 2.5 kit, rear brake line extensions and Dirt parts dual battery kit. Also got a good deal on metal tech rear trailing arms so I figure why not. Also, got EBC rotors and pads for the front because they will be needed very soon anyways.
I also got a pair of OME 895 springs....not sure why but I think I was afraid of having to much lift in the front and the rear sagging a little. Anyone think I should put the OME or another spring instead of the Radflo coils? ill probably end up selling these springs.. also have 700lbs springs on my front coil overs since I have a ARB bumper, winch and soon a second battery.
I'm going to attempt to install this kit this weekend because of good weather. I've put many springs/struts, coils, shocks on other vehicles so I hope this doesn't turn into a disaster....! I'm addicted!!
Any tips or comments would be appreciated. Thank You!
utkrstam
