Radflo 2.5 w All Pro 3.5s
C C
Member
Hey everyone,
Is anyone running the Radflo 2.5 setup up front and rear with rear All Pro 3.5 springs?
If so can I see your pictures
Thank you
Yep, no problem. It's funny. Last suspension set up you were asking about, was the same one I had. And this time, it's the same one my buddy has, lol.
I'm running radflo 2.0 front with all pro 3.5 rear. I also have a 1.5" body lift.
You dont have any driver side lean with this setup do you?
Not really. I think I measured about a 1/4'' difference, so I cranked up the front driver coil a little bit and it seems gone. You could also throw a trim packer in the driver rear coil and it should be perfect.
Yeah I knew about that just didn't know how I felt about using a spacer
Do you have the link for the exact setup you bought?
Here's the link for the radflo's. I ordered the 650lb coils since I have a heavy bumper and winch. http://toyteclifts.3dcartstores.com/Radflo-Adjustable-Front-coilovers_p_264.html
The all pro springs I purchased direct from all pro offroad. As for rear shocks I went with the icons that can be found here.
http://toyteclifts.3dcartstores.com/Rear-Icon-Shocks-FJ-03-4Runner_p_77.html
I couldn't be happier with the ride and suspension overall.
Here's the link for the radflo's. I ordered the 650lb coils since I have a heavy bumper and winch. Radflo Adjustable Front coilovers
Rear Icon Shocks (FJ & 03-11 4Run)
Thanks for the help that is exactly what I was looking for, do you happen to have any pictures of that setup before the BL?
I have no complaints on the setup either it rides great, only thing I'd change is putting a straight axle up front :rockon:
Hey everyone,
Thank you
Depending on how much you will be carrying load wise keep in mind the spring rate of the AllPro springs. They are ~ 15% stiffer than stock. I also looked at the AllPro springs but I usually have 200#+ in the truck all the time. On trips that is 500#+. The superflex's I has initially were 15% stiffer than stock and sagged about 1" with my regular carrying load, much more with trip loads.
I moved to the OME 895 (medium) which gave me 2" lift, 45% stiffer than stock and I get ~ 0.25" sag with 200#+ load, not much more under trip load. I was pleasantly surprised.
Those are just my 2 cents.
Appreciate all the replies,
If I go with a Radflo 2.0 or 2.5 with Icons in the rear with All Pros will I have to change any other suspension components
You might have to use the swaybar relocating brackets in the front, and or extended rear sway bar links. I also recommend extended rear brake lines, but at the very least you must relocate the bracket. Other than that, you're good to go.
How do the AllPro 3.5's compare to the 700lbs Eibach's Andre provided with his 2.5" OLW kits?
Are you sure Andre was providing a 700# rear spring?
The AllPro 3.5's are approx 207# rate. Stock is 180#.
I thought Andre offered 650# & 700# front spring options.
I was under the impression that they were 700lbs all around, I know when I ordered mine Andre asked me what I wanted to do with my 4Runner and suggested I hold off a bit as they were waiting for another shipment of the 700's from Eibach at the time.
I'll shoot him a PM later today when I get the chance on T120.
Jhunt
