Radiator and Trans problem
ZASKRONIEC
I have two 4runners both 1999 Limited model. About two months ago my transmission broke due to faulty design on the radiator connection (looks like more then 1999 year has this problem) Supposedly Toyota made a line that connects the transmission with the radiator out of aluminum but they used a fitting out of metal which over time corrodes and caused the radiator fluid to mix with the transmission fluid. This will create huge problem and you will not notice it until your transmission will start to act weird and after a while your engine and trans will overheat (coast to fix is about $2200 + if this happens)
The easy fix to it is to replace the radiator which will cost from $220 to $280.
I
