Radiator bracket bolt size
Tyler992
Hello all, I'm looking to replace my radiator this week, as I pressure tested it and the leak is definitely coming from the top and bottom seams of radiator. But the bracket bolts are all rusted and I would like to replace them with new bolts. Not sure if I should get 8 bolts. Because theres four brackets holding the radiator. I was just going to take off all four brackets, and sand down the brackets and rust convert them and put new bolts in. Only problem is I don't know what size or pitch bolt to get. I tried looking everywhere even on Toyota parts can't seem to find the bolt or part number for the bolts anywhere.
Any help would be great! Thanks!
It looks like from this diagram that it’s 91626-60818 qty 4. Bottom left corner of the exploded view.
RADIATOR & WATER OUTLET. Toyota 4Runner | John Elways Crown Toyota, Ontario CA
Thanks I've seen that schematic before wasn't to sure. I'm going to replace those bolts while I change the radiator.
AndiGarage
