Radio Issue
SIXPACK009
I am sure this has already been addressed but I can not find my Antenna inside my vehicle.... Its a 05 4R Sport Edition. Have not made any changes its all stock. Only thing different is the 2 TV head rest in the back. It came like that. Any clue would greatly be appreciated. I need to find some way to have a better quality radio.
So do replace the glass or is there a way to take said antenna out of it.. I am also guessing since its back there that it could possibly be a breakage or something interfering with it between the window to the radio its self.
Is there like a way you can just put an external Antenna up. Just doesn't seem like that was a good idea. Even worse when I roll down the back window it makes the connection even worse barely hear anything other than white noise.
You can run a external one it was a good idea because it made the truck look cleaner and the antenna window doesn't roll down have you pulled the radio out yet to be sure the antenna isn't loose
Nope I haven't pulled it out was afraid it might break but I can give it a try. I understand the back passenger window doesn't roll down but the center rear one does and that's the one i was referring to as a worse signal.
Thx for the comments will have to take on this challenge on a weekend possibly and hope nothing breaks, since it has never been removed Im sure its all brittle
Ya pulling the radio is no fun you have to pull the entire center consule out and faceplate with the a/c control buttons
Compared to some vehicles...this is pretty simple...Just ONE bolt to remove the entire center console. Then it just snaps off. Disconnect the wires (although you don't have to) and then you have complete access to the radio.
ghengiskhan
