Radio - need schematic
Brian1973
Member
Not sure if this post is in the proper place but looking to identify my stock radio's wires for a 3rd gen (not limited).
Also curious, does everyone's radio start out SILENT when in AM/FM mode and starting the truck? I have to hit the FM button a couple times to get sound... if I turn off the truck, then back on, have to hit the FM button a couple times again...
thanks, and maybe I'm missing it on the schematic but why do I have a second unused connection on the back of the radio??
Still wonder if my radio has a flaw with it defaulting to silent mode after starting the truck or if that is a normal function.... ???
Explain second port?
The factory radio comes with a factory amp. That amp plugs into the radio using those two ports.
Removing the amp with give you the wiring harness you're looking for, where you get a Toyota harness and splice it with the aftermarket radio harness to plug it in.
I see the amp behind the radio.... the plug on the left side of radio picture goes into that amp... I'm ok with that... the plug on the right side of my radio is blank. ???
Soooo, if I'm going to split the signal from the front speakers for a powered tube sub, would I go from the radio or from the amp wires? Looks like I only see positive wires from radio on the schematic???
Also, second part of my radio question - Is the radio suppose to start out silent when you first turn it on (or after starting the truck if it's always on)? I have to hit the FM button twice to get audio... everything visually is there, it's just silent until I hit the FM button twice.... has been that way since I bought it a few yrs ago and wondered if this is normal or maybe mine has some kind of issue?
