Rag Joint Bolt Size
STI_MECE
What are the OEM bolt specs that are pulled out and replaced with longer ones whenever you are doing a body lift?
These are the final two bolts i need to get to be able to successfully remove the body lift this weekend.
I tried contacting Toytec and inquired about what length bolt they supply for the 2inch but I got no response.
Tried searching the web for the stock size but no luck. i swore i have found some good threads with bolt sizes around here somewhere but I can not pull it up.
Time is ticking till i start busting butt on it! I live out in the middle of no where so whatever i can grab while I got nothing can do saves me half a day!
Someone help please!
Well I think I found it.....but not 100% sure if that's the OEM length.
Bolt size is 8x25 (diameter x length).TPI is 1.25 if I recall correctly. You will need flanged nut
OEM is grade 5, don't think you can go wrong with grade 8. Torque spec is 15-20 ft lbs.
If anyone believes this is wrong please chime in. I'm going to hardware store tonight before I start my drive back home.
For reference, I live where you guys like to drive the 4runners on trails. IE. In the middle of the no where lol 1 screw up and it costs me half a day minimum to get a bolt.
Found it here: Body Lift Installation Instructions
Ambrose67
