Rain driving is uncomfortable at best
TejasRunner01
Hey guys, I've noticed whenever I drive in the rain I feel that I don't have much control in the steering. I feel a constant pull to the right and left. I'm at 99 tall spring ride height with 15" stock rims and tires. It is bad enough that during pretty decent rain I don't feel comfortable going past 50 mph due to quick pulling of the wheel mainly to the right. Most of the time I have to pull over and wait. On dry roads the truck is flawless. Any advice or input is appreciated! Thank you in advance.
Sent from my A0001 using Tapatalk
These are old trucks and most have a lot of miles. Very likely a worn steering rack/bushings, tie rods, etc. Any of these can cause bad tire wear which just eccentuates the problem.
I have Firestone Destination LE2s. For on road wet driving I don't think there's a better tire save for maybe the Michelins. And you gotta be willing to shell out some $$$& for that.
Is it all roads or just certain roads?
In the city or only on the hiqhway?
Do any of the roads have well worn ruts that collect water?
Here is a picture of tires. They are probably 5 years old (update, they were 10 years old) but have a ton of tread left. They still have a good bit of oil left in them, no dry rot or cracking. Now the alignment is possibly off, I have never had an alignment done since I've had it for the past year. There is not really any pulling/drifting in any direction on dry roads when I let my hands off. I will add that I have new sway bar bushings since redoing shocks and struts.
It's your alignment, almost guarantee it.
A month ago I had no issues whatsoever in rain. Since then I've done Inner/outer tie rods and know I didn't align things properly. No big deal when things are dry, but my truck tries to kill me every time I go 40+ in rain.
Here is a picture of tires. They are probably 5 years old but have a ton of tread left. They still have a good bit of oil left in them, no dry rot or cracking. Now the alignment is possibly off, I have never had an alignment done since I've had it for the past year. There is not really any pulling/drifting in any direction on dry roads when I let my hands off. I will add that I have new sway bar bushings since redoing shocks and struts.
I correct my first post, Michelins are some of the best road tires out there.
Looks like either the alignment has gone out of whack or you have play in the tie rods, causing sloppy steering.
After installing Discount Tire's Trailfinder A/T 265/75r16s and getting an alignment my truck feels very solid in most rain situations.
Thanks for all of your help everyone!
I will certify--I have those exact tires (in 16 inch) and they are fantastic in the rain. Bad were the factory Goodyears; I hated those damn things and junked them at 40k for Michelins (first set). Night and day difference.
Mike Sargent
