Raingler Net *Group Buy* Winter 2015
jicko
* 2/1/2016 *
This GROUP BUY is now *closed*. Thanks for your participation! BE SURE to post pictures when you get your nets!
Due to some emergency, I was offlined for the past 6+ weeks.
If you have signed up for this group buy, you should get your ordering code in your PM before end of day 1/22.
PS. Options added specific to Baja LONG version, please check the website, and if you need to update your order, please contact Raingler Net directly.
Jicko Group Buy Series - Raingler Net (Roof Net, Interior Net/Mesh, Cargo/Pet Barrier etc..)
Raingler is very popular in the JK world. They have been around for over 15 years and lots of units out in the field. They are making a push this year trying to get on more Toyotas and especially 5th gen 4Runners. The products are made in USA/Colorado, lifetime warranty to original owner, 10 year UV materials, and their nets are worldwide in UN and military/government applications.
They ARE AWESOME nets, and PERFECT pairing for the Gobi Rack!!!
Raingler Nets & Grips, Mesh Dog Barrier Nets
"Desert Style Roof Rack Rear Net" and "Desert Style Roof Rack Front Net" are custom fitted for 5th gen Gobi Roof Racks (I believed it also work for other gen tho. If you do not have sunroof opening and I believed there is a way to order a "full net".
Color options: standard SWAT 2000lb 2” black or MILSPEC OD green for a small add't charge. All black hardware and 24’ adjusting straps.
If you order the rack net, anything else will get the same extended discounts too.
I am trying to get us good percentage off, again, we do need numbers.
To get on the list:
Please PM me your full name/phone/email/vehicle model & year/what you may want(in code format, see below)
Sample PM:
Megan Fox
818-999-0210
[email protected]
T4R 2015 TE no KDSS
foxygirl [2015 TE no KDSS/gen5+, RoofTopNet Set for 5th gen GobiStealth]
These instructions are NOT difficult to follow, right? (Many in the previous GB read and follow the instructions, thank you; but there are always a few that just don't seems to get it, *puzzled*)
0. foxygirl [2015 TE no KDSS/gen5+, RoofTopNet Set (front and rear set) for 5th gen GobiStealth]
1. TheWraith [2014 TE KDSS, MIL SPEC BLACK RoofTopNet (full net) for 5th gen GobiStealth]
2. coykili [2016 TE KDSS/gen5+, Barrier Net black for 5th gen]
3. grywu623 [2015 TRD PRO, RoofTopNet for 5th gen GobiStealth, Interior Cargo Net]
4. cmilviper [2015 4Runner TRD Pro (No Sunroof); RoofTopNet for 5th Gen Gobi Stealth; Color=OD; Full Net if available.]
5. oshaughnessy [2015 SR5 no KDSS, Roof rack front and rear nets for 5th gen 4Runner with extension straps]
6. badduc [2006 SR5/gen5+, RoofTopNet for 5th gen GobiStealth]
7. mtomaro [2015 TEP, RoofTopNet (main/rear only) for 5th gen GobiStealth]
8. COgreen [2015 TEP KDSS, RoofTopNet for 5th gen GobiStealth (rear, black)]
9. Spenny [2015 Gen5 no KDSS/ Roof Top Rear Net for 5th Gen Gobi Stealth]
10. py2o3434 [2015 TEP KDSS/gen5+, RoofTopNet for 5th gen GobiStealth]
11. jmf_tracy [2015 TRD pro /gen5+, RoofTopNet for 5th gen GobiStealth black with ext straps and black h/w]
12. RussToy [2000 SR5/gen3, RoofTopNet/ExtraSunRoofNet/GrabHandles]
13. k2lip [2015 T4R TEP/Desert style roof rack front and rear nets in black, both with extension straps for 5th Gen Gobi Stealth]
14. -dustin [2015 TEp no KDSS/gen5+, Front Roof Top Net, Rear Roof Top Net with Extensions and Grab Handles]
15. davester00 [2014 SR5P 4x4, 4RUNNER 5TH GEN CARGO AREA NET(COLOR P202 (202 RS4N + 4x151)]
16. PNW4R [2015 TE KDSS 5TH GEN/ MIL SPEC BLACK RoofTopNet for 5th gen GobiStealth]
17. delloro [2015 SR5 no sunroof, no KDSS/gen5+, full length net for 5th gen Drabbits rack w/o sunroof cutout]
18. EL CID [2014 T4R SR5/Desert style roof rack rear net (black) for 5th Gen Gobi Stealth]
19. Hamburgerpimp [2014 TE KDSS, MIL SPEC BLACK Roof rack front net (front net only) for 5th gen GobiStealth]
20. Moodywizard [2007 FJ cruiser, universal 2 inch net 42x82 to fit my Baja rack]
21. Inferno1 [2015 TRD Pro 5th Gen--front and rear roof rack nets in black for Gobi stealth, barrier net in black and ceiling net in black]
22. trey99ek [2008 T4R. 5th Gen Gobi Stealth Net, Black.]
23. jdtaylor42 [2015 TE KDSS/gen5+, Roof Rack Containment Net Large, Color Black, for universal rack]
24. raisedbywolves [2015 LE no KDSS/gen5+, RoofTopNet Set for 5th gen GobiStealth - rear and front - OD GREEN]
25. Bob J [RoofTopNet front and rear nets (black h/w) for 5th gen 4Runner + extension straps + Universal ceiling net blk]
26. Mistaken [2011 Limited/gen5+, RoofTopNet Front for Gobi Stealth 5th gen, black in color]
27. PDPGAUGE
28. jhmiller [2014 SR5 5th Gen--front and rear roof rack nets in black for Gobi stealth, barrier net in black and ceiling net in black]
29. team360
30. Desert_Runner
31. Hollow4
32. omegadeluz77
33. anferneey
34. ENGRDRUNNER
35. JWaldz
36. Fimbulvetr [2012 TE KDSS/gen5+, RoofTopNet (full net) for 5th gen GobiStealth, black, per Raingler this will fit Baja Rack SPY utility rack]
37. m10karind
38. Pittsburghese [T4R 2006 SR5, RoofTopNet Set for 5th gen GobiStealth]
39. clydeepants [2014 SR5 no sunroof, no KDSS/gen5+, RoofTopNet set for 5th gen Drabbits rack; Color=black; Full length net if available]
40. Split [2016 TEP no KDSS/gen5+, RoofTopNet Set for 5th gen GobiStealth - Black]
41. R4nnerR4nner
42. bubbles
43. bigears2303 [2014 SR5 /gen5+, RoofTopNet for 5th gen GobiStealth black with ext straps and black h/w]
44. howlindaug
45. Bao!OhNoes
46. Ammomac
47. SDJ
48. lipek
49. Wingman707
50. Aznwolf118
51. grapemilk
52. act1v3x
53. DFW_TRD
jary5a7e.jpg~original
261533_ffdec40e3ed04a53a211529ef9ba53e9.jpg~original
Dang it!! I just bought mine about a month ago. I used them to hold my snowboarding gear and it worked great. We had about 60mph cross winds coming home from the mountain and non of the straps loosened and stayed as tight as when I put them on. They don't make a 4th gen roof rack netting but I used the 5th gen and it worked fine. I also purchased the pull handles too which work great.
here are some pictures of my setup, let me know if any one has questions.
It really would be nice to start seeing prices or discount types on these group buys. I've done group buys and so have others and it's never been a secret, maybe it's just me , i dont get it.
Edit - I do thank you for setting this up.
Anyone know if they have the nets roof nets for a 4th gen, or if 4th gens are using the 5th gen nets id love to see pictures. Only 4th gen stuff i can find are cargo area nets in the back.
Apparently you didn't read the thread!!
The second post I mentioned that I have a 4th gen and I purchased a 5th gen roof rack netting and it fits, I also posted pictures. I have a custom full length roof rack that is about the same size as the gobi if not larger then it. All the straps are adjustable to fit your needs.
Well now i feel really dumb. I dont know how i missed that. What are the handles for? To snug it down or are they hand holds when retreiving items from up there?
No worries, it happens to the best of us.
I got the handles as a cheap addition and I noticed they came in handy when my rack is fully loaded and I can't grab the rail to get up there. So I can grab the handles to get up there or if I am loading things up there and I start to fall back it gives me something to grab on to.
These look useful even if you don't have a full-length rack. I'm guessing the larger net (the 2/3 size) would be pretty convenient on the factory rack (since I don't have a full rack yet. :^)
What are the extension straps for that Raingler offers? Are those just to let you put larger things under the net?
Anyone use one of these with a 4th gen Whitson rack? I would assume that it is adjustable enough to fit nearly any full length rack.
Hey [MENTION=119516]jicko[/MENTION] the gobi net is that the full net ???
I want this exact roof net but in black:
I beleive your correct about the extensions. Theyre also for sale indivdually if you look under the raingler extras section in the store they call them tie downs. Raingler Nets & Grips, Dog Barrier Nets
You just select what size you want from a drop down menu.
How can we get measurements on this net? On their website it just says 24" perimeter adjustable straps but does not list the dimensions of the actual net area. I do not have a sunroof, or a Gobi that has separate sections, so I would like one full-length net but curious on dimensions before putting my name down.
I emailed them about that:
* The rear Gobi net is 36x52".
* The front Gobi net is 36x18".
I measured the dimensions of my factory rack. It's 44" wide between the outer edges of the side rails and 40" long between the outer edges of the crossbars at the max separation adjustment.
Pm sent to be on the list.
I'm to looking forward to see the exact messurements of the cargo net. As long as this fits...wow..what an awesome accessory for my rack!! :spy:
Great Solution
This looks like a great solution for gear storage! I am looking for something to secure my snowboards on a platform style rack with t-slot rectangular bars instead of round bars. Can't seem to find an adapter to fit my Yakima ski attachment so this could work. Have you seen anything to work with 1"x2" t-slot bars? Thanks!
This is the full net.
But you may want to consider getting the "large" (rear) and "small" (front) set. They can be connected to form a full net, WHILE you can use them separately to secure items of varying sizes. I used this configuration, found it very versatile and nice. You can run the large in front, and the small in the rear...... while having the large tie'ing down lower profile items in the front, and having the small one tie down a row of jerry cans....
I had these nets on my xterra and they're too notch plus great company. I'll be ordering at least roof net for Gobi stealth, dog barrier and roof net in black
Alright [MENTION=119516]jicko[/MENTION] sign me up for front and back for my gobi rack in black pls...
Can you post pics of your set up ???
