Rancho QuickLift Loaded Struts RS999907- Opinions anybody?
I am not positive on this, but I think the top hat bolt spacing might be different from the 4runner to the Taco. I think they use different top hats. If so, you will have to disassemble the quick strut anyway. Others will know for certain and likely chime in soon.
Edit:Yes. Different part numbers for 4runner and Tacoma top hats. You will have to disassemble these.
As well, springs and shocks designed for the Taco will not be designed for the 4runner so you take your chances on how they will ride and what height they will sit at.
If they are cheap enough and you are keen enough you can experiment. They are not too hard to switch out.
Ah that makes sense about the tops. If that's the case then probably make more sense going bilstiens.
PRWhite
