Rancho Shocks
SCRunner12
So I'm pretty sure I already know the answer, but can rancho shocks from a ford fit my 95 t4r? The woman selling them said they were either from a ranger or f150. There is a set really cheap on craigslist and I'm on a budget. My t4r is stock and has the factory shocks, so they need to be replaced. Thanks.
Too many unknown variables to be able to tell.
Ranger or F150?
2wd or 4wd?
What year?
I would bet they will not fit.
Yeah the people were real vauge. It is the wife that is putting them up for sale. They said most likely a 2007, 4wd and thats about it. I'm just going to assume they won't fit.
If you have that info you can compare part numbers on Rancho's site for your truck and theirs and see, but I doubt it will match up.
Shocks
Climb under your truck and measure the length of your shock center to center with the weight on your wheels. Make that your midpoint, then call the guy on Craigslist that has the shocks you want and ask them for the measurements fully compressed and fully extended. Take the average of those two numbers and see if it's close......The shocks that I put on my Runner are 1.5" lift for a Ford Bronco.
Good Luck!
Good Luck!
Ok maybe I'll try that. So the connection points to the suspension will work though if it is close? Thanks for the responses.
