I have a question for you v8 folks with the RAS. I have a v6 limited and will be installing some air bags for towing and I am hoping I can use one of the v8 center console switches from the factory RAS with my aftermarket system to raise / lower the suspension. It would be nice to fill one of the blanks I now have in my center console with a functioning switch.
I looked over a number of parts diagrams and found several part numbers that may work but I am unsure as I don’t have a good picture of the switch(s). One appears to be a simple on / off switch but I can’t tell what the other switch does. Can one of you v8 guys / gals that have the RAS tell me what switches you have, their position in the console and what they do?
Also, from my reading it sounds like the newer 4runners just have auto leveling RAS. Does this mean you cannot manually raise / lower the suspension? I ask this because somewhere I read that some 4runners, maybe the 04/05, had a switch that allowed you to adjust the height manually. Can someone confirm if any of the models have an up / down type switch for raising / lowering the RAS?
Thanks much!
Thanks much!
