rear 12v 400w outlet
Correct me if I'm wrong...
volts X amps = watts so....
pressure washer runs off 120 right?.................120 X 13 = 1,560 watts!
So I'd say no even if you figure the washer runs off 110v.
I think 3-4 amps would be a safe range. Small appliance (not toaster or coffee maker) I find it most useful for charging tool batteries and LED lighting.
anyone know if thie outlet can support his air compressor
Campbell Hausfeld Twinstack with Inflation Kit, 2 gal., Prop 65 Compliant. its on tractorsupply.com. draws 2 amp. whats the most you guys have done with the outlet and for how long?
i wonder what it draws when the compressor kicks on. i was going to mount one in the vehicle or engine compartment but if i can use it at the house or construction sites why not. its more practical
Well the power outlets fuse #30 on the driver's side fuse panel is a 15A fuse. That's on the 2013 SR5.
