rear air spring with automatic leveling
wvuviv30
I am looking at installing a set of airbag within my rear springs that has automatic leveling for when I tow my trailer.
I tow a 5x8 with about 3k-4k in weight. It drops the rear end down 2"-3".
I would like to have an automatic leveling system for the rear. Who makes the best set-up of plug and play (minimal fabrication is ok)?
Performance Products has a kit from Air Lift called the Smart Air Automatic Leveling System... Anyone have this kit?
Edit: I just noticed that this kit doesn't work with the Air Lift 1000 system. But I am looking for a system that works like this.
I have the sure set system with 1000's. It levels the load nicely and it beats manually inflating the bags. Installation took a long time though... 7hrs long. Granted that is a really clean install.
Forget it, the cost would be ridiculous. Just get a set of air bag with an onboard compressor and lift it till its level.
Koz
Foos, did you have to figure out a PSI to keep the 4Runner level with a certain load? Or does it automatically adjust the height after I put the trailer on it?
can you post a pic of your install?
Koz, you adjustable rear suspension, is that Factory or Aftermarket?
