Well.... I'm worried my rear air-suspension air-bags are leaking.
I have heard and read about people having issues with the rear-air sensors due to salt from roads in the winter... and yes, I'm from east coast Canada and we have PLENTY of salt in the winter. So that may still be it, but....
...the big difference being that it seems that everyone that has had that problem, it has caused their air-bags to go all the way up and then they could not lower them.
Mine however is lowering not rising.... and the air-suspension still works fine. So whenever this happens (almost daily now) I just raise the rear to the "high" setting, then back to the "default" level setting and it rides fine again.... for a while that is. :redbrick:
It is just getting very annoying. And I have been trying to keep the undercarriage clean (washing it with my pressure sprayer) but it doesn't seem to help much. I'm trying to let it ride until the spring/summer before doing anything, to confirm if its the salt or not, but even if it
is the salt, I'm thinking I'm going to have to swap out the air-bags for coils because it'll drive me crazy in the winter.
Can the rear-air bags be set in the "normal" position and then "deactivated" to make it stay like that? If so, if it wasn't too much effort, I could do that just for the winter. Then re-activate in the summer for towing purposes. Sucks because the rear-air was a key feature I wanted for towing.... now it's driving me crazy. When it drops down it is bouncy as hell and not a fun ride.
My rear fender wall height (from the ground) is typically around 36-36-1/2" driver side and 36 3/4-37" pass side.
But it now keeps dropping down to between 34"-35" driver side (34-3/4-35-1/2" passenger side.
Can someone else post what heights they get on their rear-air suspension in the "lowest" setting and the normal "level" setting?
