Rear airbag questions
confyushus
I bought a hitch mount carrier for my dirtbike so naturally the rear sags a decent amount (superflex coils, extended bilsteins). I know that using the toytec airbags will help tremendously, but how are they off road? I will be carrying my bike and gear a good bit so the bags will be used a lot, but I also go offroad a good bit unloaded and am worried about pinching one or something like that while flexing the rear. Does anyone have any experience with this or any recommendations?
Just pull the valve core out if the full port and you're good. Did that with no issues for a couple years
Ok, thanks guys. I planned on deflating them unless loaded down, but I guess was just worried about the bags getting caught between the coils when one side is stuffed. They must be more rigid when deflated than I am thinking.
They actually fit all the way inside until they are inflated. When they are inflated that is when the bags pushes itself out of the coil creating a "lift".
Ok, that makes a little more sense as to how they would be safe inside the coils. Thanks for the help! My kit is on the way!
2001ATL
