Rear axle bearing puller tool....SoCal
hugo2go
Just wondering if anyone had a homemade or SST tool for the rear seal job to be completed.
I have a press, but need a tool to complete the job.
If anyone has one in the SoCal Area (Im in Pasadena) , I will pay to borrow the tool for the day.
Thanks in advance.
what's the spec of your press? I've read that it needs to at least 15-20 ton press.
I have a spare housing that you can cut and create you own SST. It will look something like this.
Save yourself some time and just drop it off at a machine shop. Napa took everything off and pressed the new parts on for $65. Drop it off, pick it up in an hour or two, done.
Edit: just read that you HAVE a press, I read that backwards. You'd still probably save time if you just take it in, just not money.
Which napa shop? Please do share cause the cheapest quotes I got was around $100-120 / side.
Yea. Which Napa charges that much to do it??
Found one on ebay for 160 shipped, but dont know if its worth it. Since this is the last time I will be doing this axle seal job
Expensive. Aren't these all you need? ($30 each)
http://www.cjponyparts.com/eastwood...ign=shopping&gclid=CN670_3qw8gCFVKEfgoduZEELQ
And something similar to this ...
http://m.summitracing.com/parts/yga-56063?seid=srese1&gclid=CNbcmpvrw8gCFUZqfgodongG5w
And you read this right?
http://www.toyota-4runner.org/3rd-g...e-information-replacement-thread-3rd-gen.html
And this thread? (Via the Google magic)
http://www.toyota-4runner.org/3rd-gen-t4rs/65722-rear-axle-seal-tool-please-post-photo.html
The ones that have machine shops will do it for cheap. There's two within 10 min of where I live, but not sure how it is in other parts of the country.
P.S. stay away from the harbor freight seal pullers. I broke mine in half on the first pull attempt... lol.
I never said I need an axle seal puller. I need the SST tool or something similar to press out the bearings, not the seals. I can take it out safely with a small pry bar
Nomadik_Overland
