Rear axle/brake noise, need help!
CalBlackSheep
Hey Guys,
I'm getting a weird noise coming from the rear end, and no it's not gas!:toilet:
Here's a video I found of the same noise but whoever posted it didn't say what it was: https://youtu.be/Ch7e_8lj2ik
One of the comments says it's a wheel bearing, which it probably is. But I'd like to confirm before I pull the axle. The only difference between mine and the video is I mainly hear it when braking or at slow speeds. But it comes and goes and every time it comes back/when I start noticing it again, is while I'm braking. Then it might stick around at low speeds for a while.
I've pulled the drums and everything looked pretty good, but I still cleaned everything up with some brake clean. Then re-assembled and then used the e-brake to adjust them.
Also, I have service records from the previous owner. Showing they had the seals and bearing replaced on this same side 30,000 miles ago. So yah that sucks!
delislerebecca
