Rear Axle Seal
kpnavarro
I have a bad rear axle seal on a 1995 4runner and was wondering if there are any good write ups on how to do this
I'm not sure if mine is the same as yours, but i had to use a press to get my race and bearing in when I did my wheel seal. Do you have good diff breathers? If not your breather could be clogged and causing the seals to go out. What happens is the temperature changes in the axle causing pressure buildup, and if it can't be released through the breather hole, It'll push out your seals. Just a suggestion
Clocktower07
