Rear Axle Seals & Bearings
can someone point me to what type of sealant i should use to seal where the retainer ring meets the axle (and where the inner seal meets the axle housing)?
thanks!
Was about to make a thread on this, but I figured I could ask here seeing as this is an active thread on the same general topic.
The rear seals, bearings and retainers were all replaced on mine 3 years ago. Flipped retainers and was grease tested. Grease test showed right in the middle. No leaks.
Now, in a month or so, I am getting ready to install a 4.10 locker with the accompanying locker housing. I have new axle seals and the axle o-rings ready to go on the new housing.
My question is, would I need to play with the retainers at all? I am merely just taking the axles from the old unit and transferring it onto the new housing, so I believe the retainers should still be in the correct position to make a seal on the new housing.
Regardless, I was still planning to perform a grease test to verify, but I just wanted some input before I begin. Thanks.
In theory it should be in the same spot, but grease or sharpie test to verify.
Quick update. I redid both rear axles w/ new seals and a new inner retainer rings. I used the FIPG on the outside edge of the seals as well as the inner face of the inner retainer ring where it wraps around the axle. 3 weeks. no leaks. going to do some light wheeling tomorrow and see if there are any leaks. fingers crossed!
another update. no leaking seals since replacing the retainer ring and using the sealant. have towed 4k lb trailer overlanding too (repeatedly).
