rear brake cylinders 1997 4runner.
bilgsmf
Wondering if anyone on this forum has direct knowledge of the difference in rear brake cylinders for 15" and 16" rims? Went to Autozone and purchased wheel cylinder for one side of rear brakes. I have 16" rims. It was later determined afterwards that the cylinder that was installed was for a 15" rim and that there is a different brake cylinder for 16" rims. The difference is the diameter of the brake cylinder. 15" is 15/16" whereas the 16" is 1".
Does anyone know if it will make that big a difference if i just leave the 15" on?
You must use to cyl that your rig came from the factory with. I don't think :thumb3:you can even mount the wrong cyl if you tried.
D'Angelo
