Rear bumper upper plate Plasti Dip
llennium
This is my first write up so bear with me on this and I hope it helps someone else.
I purchased my 02 4R a few years ago and due to scheduling haven't been able to commit any time to fixing it up until recently. The Runners color is Thundercloud which I think looks great but I'm not crazy about all the chrome. I have decided to black out anything that was painted and since the rear bumper cover was looking pretty bad I thought I would start there. I have read in several forums the uses many people found for Plasti dip spray. I thought if it would work on wheels and emblems I would see how it would hold up on the top of the bumper.
This is what the cover looked like before I started. The dark gray is where the rear hatch covered the upper plate and the fading wasn't as bad.
c8043934-1.jpg~original
The process was pretty easy, disassembly wasn't bad and prep/paint was simple. Here's a quick step by step of what I did, if anyone has questions let me know.
Pulling the cover was really simple. Each corner has a tab that you pull up on to release. Once this is done pushing the top of the cover from behind released it and then I simply pulled forward. The tabs on the bottom of the cover can be squeezed together to release if needed.
This is the back top of the cover from under the vehicle. If you push on this it should release making it easier to remove. This was taken after using the Plasti Dip so yours will probably be gray instead of black. I also made sure to spray a good coat around the edges. My thinking here was that this would be the first place it would start to peel. I'm hoping that with the edges coated well this will not happen.
fdecca84-1.jpg~original
These are the tabs on the bottom of the cover that may need to be pressed together to release.
12e55709-1.jpg~original
Here you go once the upper plate is removed.
fb315ccf.jpg~original
Once removed I cleaned the upper plate with soap and water and since the sun wasn't out and I'm impatient I used the compressor and blew it dry.
I used saw horses to hold the cover and sprayed a pretty hefty first coat. I made sure the gray was covered and not showing through anywhere. This pic was taken after the first coat. You can see the original texture of the cover still showing.
a6131da9.jpg~original
7990fb3a.jpg~original
I was able to get two full coats out of a can and had purchased two cans so I decided to go for 4 coats. Hopefully this will be enough that minor scratches wont make it through the Plasti Dip and start peeling. I allowed roughly thirty minutes between coats to allow dry time. Once complete I let it dry overnight to ensure it was completely dry since it was a little cool outside.
below is the finished product. It turned out so nice I wish I had done this earlier. My only concern is how will it will hold up going forward. Will it handle the car wash after off-roading or pulling something out of the back and falling against the cover or scratching the cover when removing something. Only time will tell.
e529a845.jpg~original
b82e83d2.jpg~original
92c2594a.jpg~original
1f526299.jpg~original
Looks good.
I wish you had posted this last week. I took my trailer hitch off last week to paint because it had some rust spots on the welds, and I decided to tackle that greying step piece as well. (I also plasti dipped my emblems)
Those clips aren't real easy to get off (not as bad as the fender liner), but I was afraid I would break the two on the end until I realized they just pulled out.
I looked for some satin black spray paint made for plastic, but couldn't find any, so I started with a primer made for plastics. The stuff was clear, and actually brought back the color pretty well by itself, but I followed up with a couple coats of plain spray paint.
We've had a couple really bad storms since I did the step and the emblems and they seem to be holding up quite well. I'd like to know how the plasti-dip holds up on that step over time.
Does anybody have a method for renewing the black on the running boards? I know most people take them off, so it may not be an issue. I would be afraid to paint them since they get stepped on so much.
Looks good llennum :thumb3:
You could always sand them lightly and then hit them with spray on bedliner. This should restore the color as well as provide a textured surface for grip.
If you decide to use plastidip, you can sprinkle sand in between coats and it will give you a textured finish also. It specifies exactly which type of sand on the backside of the can.
Looks good.
Its good to hear that your paint is holding up. I was afraid it would crack and peal easily so I went with the Plasti Dip. I'm also curious if the Plasti Dip will hold up. I would really like to use this on the sill plates of the doors for better protection.
How did y'all remove the Plasti Dip from around the emblems? I'm in the process of doing mine right now and the first time I tried to get in between the letters it was really tough. I tried using my knife, but that just digs into the clear coat.
Maybe a toothpick?
Maybe a toothpick?
Sorry Clemsonfan15 my emblems haven't been plasti dipped. I was fortunate enough to find a 4R with the black pearl emblems. You can check out this link and see if it helps any.
DIY - Matte Black Emblems - Plastidip, no emblem removal required! - Club Lexus Forums
Maybe a toothpick?
yep, toothpicks work. If you have one of those platic toothpicky thingy's, than thats probably even better, but the wooden ones work just as well.
I tried the toothpick and used it, but I don't like the results. It was a PITA to get between the letters. It's pretty hard to get it to peal off even.
