Rear cabin bike mount
LTDSC
I just recently got into mountain biking and want to transport the bikes in the cab as they fit with the front wheels removed. I purchased two mounts with quick disconnects so i can easily secure them standing up instead of having them flop around on each other.
I plan on getting a 2x4 and cutting to length of the rear cargo area width. I want to get some 6" all-threads and put into the to secure mount bolt locations you see at the end in the corners of the cargo area by the gate. I will also be carpeting the board to match the tan interior. I plan to use either wing nuts with a washer to secure it across the cargo platform unless someone else has a better idea?
Ill keep this thread updated for others as well if they would like to do the same.
That's nice, but over complicated. I can take mine out and throw it in the back of the truck if I want to drive it instead.
The reason I'm a 4Runner owner now is because one of my favorite bikes was stolen off my kuwat rack. Yes it was locked.
I know it's a mess. That's the dirt jumper. Very versatile so it stays in there 24/7. And yes that's my 3rd gen cargo mat.
I'm perfectly fine with over complicated at its cleaner. No way I'm just going to throw a piece of plywood in the back. No offense, but I'm not going to do that.
thats perfect! How strong is it threaded into the tray? I have that stupid shelf as wel..
With all 3 knobs tightened down it doesn't even budge. I can pull on it with all my weight and it doesn't blink. Literally takes 30 seconds to install or remove the rack.
Anything worth doing is worth over doing :) Maybe you missed it but mine is removable too. Sweet bike btw.
Dpassmore, I made one like yours. How did you secure it to the floor at the ends? Just today I had two bikes on this mount and hit a couple of deep holes. Ripped the screws out of the plywood. The 2x4 would be more secure but I don't know how you get the bike far enough back and secure it at the tie downs.
Used this in my 3rd gen
Bike didn't move when I totaled it
When on carpet use the hook side of Velcro
You'll be surprised. I had a setup like that in the pick up
I have wheel tites and all that
I've carried many bikes many different ways
I mtn bike twice a week take all that out and put the dirt bike stuff in there on the weekend.
Or sometimes cram it all in there
I did something similar in the back of my 4th gen, but I didn't use a board. I simply drilled through the cargo shelf and installed 2 t nuts. I then bolt the fork mount to them with a pair of wing nuts when I want to carry my bike around.
yes plywood takes up space in the back but i dont even have mine mounted to the cargo hooks right now and i can still mount 2 bikes in the back without anything moving around in the back
IMG_20130415_151444_zps1362387a.jpg~original
A 1x6 works good with Velcro on the bottom. If I ever sell it I won't be asked what all those holes are from. Nothing is faster to to move. I take it out and leave it outside the carport is why it doesn't look nicer. It holds 2 bikes. The wheel tites would just take up more space. So they are in the shop.
leolediola
