rear cargo light
97RUNNERltd
My rear cargo light works when you turn it to the on postion but it will not turn on when the door is open. Has anyone ever had to fix this. Can you tell me where the sensor switch is for the door? I am gussing it is just stuck or something. Thanks
1997 T4R limited
1997 T4R limited
happened to me for a while. i fixed it by forcing the little lever as far as it could go... sort of jamming it. since then its worked in all positions.
are yo talking about the lever switch on the outside of the light (marked on, off, door) or did you remove the light and adjust it on the underside of the light after removing it? Thank you
yup!
cant guarantee itll work for you but it did for me.
i did that out of frustration too :p
hahaha i thought it was just mine. im having the same problem. it works about once every 6 months for a day or so
