Rear Coil Spring Replacement
Kfarm
I Have an 93 4Runner .
I am looking To Replace The Rear Coil springs .
Do I need To put Stock Coil Spring Back own my 4Runner .our is there Taller Coil Spring Out There To make it set Taller .
What is my Opposition .
Where Can I Pick Some Coil Rear Spring At ?
Terry
I just bought Moog replacement rear springs for my 1994. They are shorter in size making them a little more easy to install but, are a more thick coil.
The ride is very good and my truck sits nice and level once again:)
Another option are the Old Man Emu rear coil springs. They will give you anywhere from a 2-3" lift depending on the ones you get. About $150 for a pair.
Thinks for the Info Guys
Where Can You Pick up Some Of these Coil Spring you are talking About ?
Napa Has the Factory Coil Springs .
But Knot any other Brand
Terry
Terry
You can get the Old Man Emu springs straight off their web-site: www.oldmanemu.com the part number for a 1993 4runner would be OME900 for a medium strength coil, and OME901 for a heavy duty coil, ....., I would go with the medium. They charge $165 for a pair before shipping. May can find them at other vendors for $15-20 cheaper.
