rear defrost not working-02 sport
light turns on inside but will not defrost the rear window..what should i test?
Remove the panel on your rear door... Turn the defroster on and check for power at the plug... If your plug has come off of your window which might have happened... You can go to a parts store and buy that glue crap which last you a month or so... Or you can get a mini torch and some solder and solder the terminals back on your window, which is a more permanent solution... I soldered mine back on 3 years ago and still going strong.
Rafal
Also make sure the rear window is all the way up. I know my 98 has this safety feature. Mine didn't even look like it was down.
