rear diff fluid question
Army97
What gear oil should I put in a '97 3.4 with the factory locker?
The haynes say's SAE90, but in my research many people on here say 75W-90 for rear, t-case and front...
I was just at the dealership to pick up the crush washer and they looked in the computer and said 80W-90 so I bought that. Sounds like either one will work just fine.
I think the book actually says the rear diff gets 80w90 and the other two get 75w90..
But I did like the other posts, I just used 75w90 in all three. Just makes it easier when buying it. You will be fine with the 75w90..
Do you guys use 75w90 shockproof? superlight, heavy, or lightweight?
Truck has the heavy shockproof in everything. Most of my cars i run the lightweight shockproof. you will probably be find with either though. Best gear oil you could ever run. Especially for a manual trans.
Awesome!! Thanks, and yes, I too run LW in my cars as well. :cheers:
Does anyone know if we should use any special additives in addition to the gear oil and does it matter what type of gear oil? (GL4, GL5...)
You want GL-5 in gears.
You want GL-4 in manual transmissions. The extra surfer in a GL-5 can damage the syncros.
You're overthinking this. I use the 75-90 cheap dino oil from Walmart and change it every 50,000 in the diff and transfer case.
326,000 miles later.......no problems.
Rather than do a whole new forum post I thought I'd join in on this thread and ask a quick question similar to OP.
I'm about to do my differential fluid change as well and bought some MasterPro GL-5 80W-90 Gear Oil. However, my manual says that you should only buy 80W-90 if the car is operating at temperatures below 0 degrees F (I have a 2000 rear wheel drive 4Runner). For temperatures above that it says to get SAE 90.
Does this honestly make any difference? I don't want to put in the wrong stuff, but I just wanted to make sure. What do you guys think?
I've always ran Mobil 1 75W-90 in all 3 and the crawler. This worked in my 01 Taco, 96Runner, 04Runner, and my 00Runner.
