My 08 2wd V6 4Runner with 47k miles has a rear diff "whine". I took it to my local dealer. They drove it, checked the fluid level and did what they called a diagnostic check. The diff whine is obvious in that you can release the gas and the noise fades away and comes back again and increases in pitch as the gas is applied again. In the end my dealer told me he couldn't repair it under warranty with these points to note:
1) dealer says it has a "slight" abnormal noise in the rear diff but his technicians can't say for 100% sure where it's coming from - pinion bearing, carrier bearing, ring gear to pinion gear setting, etc. (my wife even complains about it it's so obvious and she's far from "mechanical").
2) because they can't fiqure out for sure where it's coming from, if he warranty's it, he admitted he's afraid Toyota will "call" for the repaired parts. If, after thet fact, Toyota "tests" the replaced parts and rules that it wasn't bad enough to repair under warranty, they will then make the dealer refund the cost of the repair back to Toyota. And, the service manager flat out told me, he has to answer to the dealership owner's and it's "all about the bottom line"...(very unlikely Toyota will actually honor the claim, me be out the door with a repair then Toyota will put these parts through a test to find they don't agree they should have been replaced under warranty).
3) the service manager assured me if anything needs attention, it will surely get worse and even if it this happened after the 60k mile warranty is out, Toyota is good about fixing them anyway! (amazing given the noise is very evident now yet the dealer says he can't justify the repair to Toyota now when the car is under warranty).
My position to the dealer is this - no amount of whine from a rear differential is normal or acceptable. Although I'm sure it's not common with a Toyota, it does exist in my Toyota, it is a quality issue that shouldn't never rolled off the assembly line that way and Toyota (not the dealership) should make it 100% correct under warranty. Period. If I had wanted Dodge quality, I would have purchased a Dodge you know? It's not my concern as the customer that his technicians can't specifically locate exactly what is causing the whine in the diff. If that's the case, Toyota should replace the entire axle assembly (diff and all) and the problem is surely solved - it just makes good sense. But, without question, I should have a quiet rear diff regardless of how the dealer has to "justify" the warranty repair to Toyota.
I'm no idiot and I'm frustrated and don't know how to proceed. I have a good understanding of cars having wrenched on them for years and being a mechanical engineer by day. What should I do? Who should I contact to get this resolved? Thanks for any opinions, comments, etc.
