Rear Diff Leak
PWD4R
I searched around and I mainly found ones of the diff breather leaking or being clogged or the fill plug was leaking after a recent change. I don't think those apply to me so here's what I have and the quick story.
I got my diff fluid changed about two months ago and I check it weekly to make sure it's all good. Always dry on the outside even after off roading. Went out 2 weeks ago on Sunday and I got hung up on my rear diff once (guy referred to it as a third member but I am not 100% on what the third member is)
I noticed some rock chalk on my drain plug from the diff and all was dry up until today when I noticed. I know it was dry over the weekend (I haven't driven it since Sunday) so sometime between then and now the leak started. What do I need to do to fix it
Thank you all
I also noticed I accidentally posted this in the general but I didn't mean to. This is where I wanted it.
Have you changed the crush washer? Looks like it's leaking at the plug.
I am sure it wasn't changed. My main concern is the fact it happened after I drug my diff right on the drain plug. I know it's protected but I didn't know if it's enough to prevent it from being damaged. I am gonna get a new crush washer and drain plug.
Change crush washer again and tighten the nut or you can just tighten the plug to spec and see if that stops the leak.
Sent from my SM-N900W8 using Tapatalk
That's definitely a good start. I will work on that this weekend if I have time :) thank you for your guidance
I sure hope it's the crush washer. Going but what you said happened and the way that leak is all around the outside of the plug protrusion, I fear the worst. I hope I'm wrong. Please update us.
Well I hope you're wrong too lol.
Jkmazon
