NOT ME OR SOMEBODY
I wanted to do the differential breather mod, but did not like the behind the gas fill lid placement.
I instead decided to run a 3/8' hose up into the engine compartment. ( this is where TOYOTA put the center and front diff. breathers at, so good enough for them good enough for the rear I say )
So after routing the hose the way I wanted it I put the OEM breather valve on the end in the engine compartment and went to the rear end to attach it to the fitting I had already screwed into the axle housing. But before attaching it I blew thru the new hose and found it had alot of resistance. Thought I may have kinked it but it was all ok. Thought it may have been the hose length causing this so I removed the OEM breather and then was able to blow very freely thru the hose. I blew thru the breather valve and it is the cause of most if not all of the resistance. The valve seems to function as it should and I don't think it was or is clogged. ( This runner has never been off the road much YET and never in serious mud...... IH8MUD too )
Unless somebody knows better I figure the less pressure in the Differential the better on the axle seals.
Am I right about this?
So now end of the hose is mounted up high in the engine compartment and is open with no breather, and the other end is attached to the rear axle.
I don't really care for this either but I'm thinking gee whiz by the time I ever get in water that deep ....:toilet3: well you know what I mean.
Is there alternative breather valves that may work better than the OEM?
Oh yeah the threads in the rear axle are just 1/8 pipe threads so if you want just go to a hardware store and get some 1/4 pipe thread barbed fittings and adapt them down to 1/8 pipe thread.
