Instead of creating a new thread I drummed up an old one. I cannot find the information im looking for here or through google. Does anyone know what they different torque ratings on the bolts for the front & rear differentials is? Also transfer case bolt torque ratings?
I'm trying to do this today but if I dont get a good answer today Ill wait til tomorrow. Thanks.
FSM- Factory Scheduled Maintenance?
Sorry if that's a dumb question.
Factory Service Manual
It's linked in the tutorial and documentation reference sticky thread. If you havn't visited that thread, then don't make another post until you do, because most everything you will ever need is there.
you guys really need to quit putting torque wrenches on non torque critical components. The diff bolts and drain plugs and such do not need to be torqued. The torque readings for these things are not going to be accurate anyhow and you are asking for trouble. Any contamination of thread will change your reading. Oil, lock tight, cleaners, etc… all change your reading
common sense will treat you way better than the fsm and torque specs for 95% of your rig.
You guys really need to quit putting torque wrenches on non torque critical components. The diff bolts and drain plugs and such do not need to be torqued. The torque readings for these things are not going to be accurate anyhow and you are asking for trouble. ANY contamination of thread will change your reading. Oil, lock tight, cleaners, etc… all change your reading
Common sense will treat you way better than the FSM and torque specs for 95% of your rig.
Tight enough... Seriously who puts a torque wrench on crap like this?
