Rear door grommet part numbers?
81runner
So I was running new speaker wire to my amplifier in my 2007, and when I got to the rear doors, I noticed that the rubber grommets are totally trash. They are all cracked and falling apart, so I did my best not to destroy them TOO MUCH getting my wire thru, finished everything up and put some diy loom cover over everything. I would like to replace the grommets, however I can't seem to locate a part number anywhere. Has anyone else run into this situation? Were you able to replace the grommets? Did you find an alternative? Everything I've turned up in search so far only references them as part of a write up, nothing about part numbers or replacement. Any insight would be helpful.
Do you have an image where this grommet you speak of goes?
Philthyphilthy
