Rear Door Panel Removal?
Well for an 03 which I just did, two screws located under the arm rest and behind the plate behind the door openning latch then just start popping the door from the bottom. Finally lift the panel slightly since there is a metal bracket at the top and disconnect the lock and latch cables.
