I have 2 IDMAX 12's fiberglassed into the rear left side (where you normally keep your tire jack) and had the same type of rattles you guys are talking about.
I ended up putting doubled sided tape on the little plastic door on the rear tailgate as well as on the little door on the pull down strap, as they can both cause a little noise.
The shop that did my installation also glued my license plate to my license plate frame, so that takes care of that.
And then I put little rubber bumpers (you can buy these at like Target -- they're made by 3M and are supposed to be for cabinet doors, so that when you close them, they don't bang too loud) inside the gas tank door, which makes it fit tighter.
I still haven't found a solution for the rear windshield wiper and I also noticed that the tourneau cover also moves around a little bit.
But ultimately, the best way I've found to take care of the rattles is to just crank a little louder until you can't hear the rattles anymore ... works everytime. :rocker:
