Rear Driveshaft Compatability
SCRunner12
Does anyone know if the rear driveshaft from a 2001-2002 4WD work on a 2000 4WD Limited? I know they are both multimode, so the transfer cases should be the same (might be wrong), but are the driveshafts?
Good question SCRunner12, here's the answer you were looking for....
Turns out the part number for the 2000 4WD limited is 371103D250 and the 2001-2002 4WD is 371103D350. Obviously not the same part, but I wonder if it would still work. Might have to take some measurements tomorrow and on the donor truck to see if they are the same length. I'll report back with my findings for the next guy looking for this answer.
Can someone with a 2001-2002 4wd please measure their driveshaft from the flange at the rear diff to the transfer case? The donor truck has had the rear diff removed already and I don't think I'll get a great measurement without it hooked up in it's exact position. That way I can compare the lengths of the two. Thanks!
jisoo200
