Rear Driveshaft Squeaking?
Koko4
I've been having a rotational noise, which is most evident with the windows down and while starting out (forward or reverse). I hear a squeaking noise that sounds almost like a chirping, and it gets faster as I roll faster. I'm assuming it's coming from the rear driveshaft u-joint, and I plan on getting under there with a grease gun soon. I have heard horror stories about rear driveshafts on these things though - mainly I've heard that "if it's not vibrating, don't mess with it, because you're opening a can of worms". I don't want to take it off, replace the u-joint, and end up with vibration issues or other issues that are worse than this annoying squeak. Anyone else have this issue and deal with it successfully?
Literally just saw that. If a mod could delete this post before everyone else sees it.....
Jhunt
