Fuzzy Fingers
Vibration is getting worse on 2007 2WD 4.0. Yes, I've read all the threads about the rumble strips and others. Please don't post links to it. I had my drive shaft serviced by replacing the U joints and several balances to ensure we got it right. The vibrations just don't match what have mentioned repeatedly on this forum.
Still have a low speed pulse around 40 to 45 that shows up again around 60 and progressively gets worse the faster I go. The happens in overdrive and 4th. Feels like a bent tire but it doesn't seem to be the issue. I've moved my tires around and it hasn't changed it. I've had the transmission flushed. Fluid looked fine and the pan was clean with no clutch debris. However, vibration (pulsing) was there before and did not go away. Maybe a torque converter? BTW, replaced transmission mount and checked motor mounts.
The worse vibration shows around 75 and feels and sounds exactly like a bad U joint. It's not. The drive line shop believes it to be a problem in the rear end. They also mentioned the damper on the rear end yoke. Is that really a damper there and can it come loose? I read somewhere else about the drive line being "in phase". Could this be an issue?
