Rear hatch lift questions
AzHic13
So my rear hatch kept falling and trying to kill me when it got cold out, so I finally replaced the hatch dampers. Problem is when I took the old ones off, the rubber gaskets that the bolt runs through for the top connection point are completely dry rotted. I talked to the dealer and they said the only way they can get them is by ordering the whole piece (lift plus mount $250+ for each side). Has anyone else run into this or have other ideas for what I can use as a replacement? I was thinking of running to ACE hardware to see if they have anything, otherwise i'm just rubbing metal on metal.
a few days ago, someone posted on here they changed out the gas pistons that hold the gate open. I think they said they paid around $45 for each side, with shipping it was just over $100.
Just take one of those bushings to Ace Hardware and I would be shocked if they can't find something quite similar to match it to.
I'm desperately searching for that thread CapnRoo is mentioning-was it in the 3rd gen section here or over on Yota Tech? Anyways that thread also had a link to an online fasteners store that sells rubber bushings...
