rear heat problem
SASK T4R
Would anyone know why the heat for the back seating area blows air just fine but no heat.The front puts heat out just fine,is there a seperate heater core for the back possibly? Any help would be greatly appreciated
haha, mine does exact opposite, pumps out super hot air all the time. 8)
Yes, the rear heater has it's own core.
If you're not getting heat you don't have proper coolant flow to it or the core is totally clogged.
It was an option, but may have been standard in Canada, like the block heater... Neither of mine have it, 86 DLX or 87 SR5. It seems to be the only option mine doesn't have.
just had mine apart the other day and fourwd1 is right the rear has its own heat core. if you look under the truck in that area you will be able to see the hoses supplying it. if it was leaking the PO might have just bypassed it.
