Rear Hitches
slyangel9
I can't help but to notice the many different variations of hitches on our 4th Gen 4runner, even among the ones with the same engine.
What gives?
I thought there were only two? One that comes with the V6 and the other on a V8. The V6 hitch is capable of 5000lb while the V8 is a weight distributing hitch capable of towing 7000LB.
My friend has a V8 Limited and I have a V8 Sport. The hitches are definitely different and yet both can pull 7k lbs.
Same years or different years? Also run your VIN numbers, maybe they were put together in different plants (Tahara & HINO)Maybe Toyota switched to a different brand hitch during production...
Is one of your trucks a 4WD & the other 2WD? I have seen different towing gear on 2WD vs 4WD.
If you ever pulled up behind my 4Runner, you'd think something was weird...
I have a "Hidden Hitch" brand, with the label peeled off, mounted on an early-production model '03 2WD V8. I had the weaker rear-crossmember-mounted hitch before, like what the V6's come with.
Ricky
I am not 100% sure, but here is what I think:
2004-2005 V8 (all trims)- 7,000 lb hitch
2003 (all 4Runners) 2004-2005 V6 (all trims)- 5,000 lb hitch
The type of hitch you get depends on the engine, not the trim.
Mark,
Was your 2003 a different hitch than your 2005. I know you always had the V8.
I think my friend with the V8 Limited is a 2003.
Mark86, that is incorrect...
Mid-year in 2003, the V8s were changed over to the 7500lb hitch receiver. (the vehicles themselves are only rated to 7000/7300 depending on 4wd/2wd configuration).
Ricky
Ricky
Yeah I remember reading this. Early 2003 models received the same 5000LB hitch as the V6 right?
slyangel9 said:
Mark,
My 2003 Sport had the 5,000 lb hitch and it had a build date of 2/03. It is different than the hitch on my current truck.
