daugherty83
01 Limited 4x4, noticed a leak coming from rear axle a week or so ago and though it may be a pinion seal and/or the seal where the third member bolts in. Cleaned up axle the best I could, scraping rust off and spraying with degreaser. Took a look again after driving when fluid was warmed up and it appears that the fluid is almost just seeping out of one spot on axle above and to the left of the fill plug. It's weeping through the metal to the best that I can see and running down the face and dripping right around the drain plug area. Are my only options here replacing the entire rear housing? Has anyone gotten one used, and what can I expect to pay. Will most have a third member in them or am I to reuse mine? Thanks as always. Damn this NE OH rust. I will never buy a used vehicle in the north or midwest again. Arizona here I come if I ever buy again. First my rad. and the pink milkshake of doom to my tranny, and now this.
