rear long travel issue
szulbor
Hello Guys
can you advise me what I did wrong.
I have installed long travel on the rear but it seems that when I installed king shocks and I've extend bumbstop in fact i have reduce the wheel travel not extend.
thank you in advance for any suggestions.
pnPG9Bvpj
pmoWG9T4j
po1KRIQrj
poNZwHZ1j
Don’t know the shocks specs, but.
Aside from brake lines, locker harness, ect... travel is from the bump stop at the top, to the full length of the shock at the bottom.
If you put on longer shocks and longer bump stops you should have increased down travel and reduced up travel. You would then need taller rear coils to move the axle down to a position more central in the travel range.
Or like mentioned above, your shocks are too long for your current coil setup.
Cool looking Runner! Did you swap out the original rear springs? because if you just bolted on lower control arms and king shocks with original springs that’s not going to give you more travel.
I don't own a 3rd gen, so take this for what it's worth, but I agree with the above. Your shock might be too long and has no "up" travel, there by reducing your overall wheel travel. It looks like your not even going to get into your bump but about a 1/2" before your shock fully compresses. Your ride height looks pretty good, so maybe your springs are where you need them, but also like mentioned above, if you didn't upgrade your springs, all that shock travel won't do you any good. It also looks like your lower link will contact the reservoir on full compression of the shock. I would say any 4 link set up like this needs almost as much "up" travel as "down".
Here is a link to my custom length 4th gen I built with some shared knowledge from some of the Cali members. It cycles pretty well but it still needs more "up" travel, the back end still gets a little bucky which ain't fun at 40 to 60 mph. https://www.youtube.com/watch?v=OoJUF02t4bo&feature=youtu.be&t=60
Hopefully someone with more than my limited knowledge will post up and help you out.
We definitely need a full accounting of what parts you have on there... Also, looks like a 1" body lift too?
-Charlie
Hello Guys
What front fenders are those??
Ambrose67
