Rear OME890's with two 10mm trim packers?
01PArunner
Would it be safe to use two 10mm trim packers on each side with 890's for an additional 3/4" lift? Would it also be neccesary to use a panhard drop and extended brakelines with this 3.75" of lift? My Runner is a daily driver and will be used on mild to moderate off-road terrain. I won't be doing any hardcore wheeling. Any help is appreciated!
I run the 890s with one trim packer. I did not like the way the brake line looked when I flexed it a little so I put on an extended brake line (mine is a '98). As far as running two trim packers, I can not really say.
just bend the rear brake bracket down... not worth the money for the extended brake line.
panhard I would say only if you need it, Mine is at about 3.5" right now and I was able to get the panhard bar back on no problem
