Rear passenger door stuck shut
tchfall15
I followed the door actuator motor repair write up https://www.toyota-4runner.org/5th-gen-t4rs/242540-drivers-door-lock-actuator-motor-repair-[step-step-w-pics-]-7.html?highlight=door+will+-open
I did my driver's door perfect. I did the rear passenger and put everything back together except the interior door panel and my door will not open. Did I not align something correctly? Any way to get the door open?
I hooked the fork like thing around the rod of the actuator. I went from the inside to get the panel as class as possible to hook up the two pull wires for the doorlock and the door handle and the handle from the inside doesn't work. I tried moving the rod and nothing. Any suggestions?
Just an idea, have you tried pulling on the metal rods? Try pulling on both, one at a time in both directions. That may release the latch so you can access the inside of the door again at least.
Sorry just re-read, you already tried moving the rod.
CoaterZ_FL
