So I started out with a leaky pinion seal on my 97 4runner rear axle. Perhaps I should have researched before diving into this job. I had my gears replaced last year and I told them to install a solid spacer. It appears the pinion seal was the issue. It looks in bad shape. No clogged breather, I've done the mod.
So I've replaced the pinion seal and now I need to re-install the new pinion nut. I've been reading that there is a certain amount of preload that needs to be on the pinion nut? I've heard this is the case because of the crushed spacer in rear axle. Since the shop installed the solid spacer, what do I need to torque the pinion nut to? Any special techniques to torquing it down properly and since I didnt make a note of where the nut was installed before taking it off, have I screwed myself in anyway? Any help would greatly be appreciated.
