Rear Seat Permanent Removal for Overlanding
beatnik_glory
I am thinking of permanently removing the Rear Seats on my Gen 3 to be able to create a flat cargo deck. I would probably cut a piece of 3/4" Plywood for the deck and add some L-channel to be able to secure gear.
My rear seats are in the folded down position 99% of the time. but I would want this modification to be reversible.
Anyone have any advise and pics they could share?
Thanks.
Beatnik
just remove the seat bottoms and head rests, then it folds flat and gives you the head room to sleep, 4 bolts and easy to reinstall, you could even install studs and tap the correct sized SAE wing nut for the metric thread making it a tooless removal, or weld half a washer to the existing bolt.
I’d suggest using bolts instead of permanent welding or adhesive to make it reversible. This way, you can easily remove the plywood and L-channel when needed.
Built this a few months ago for the same reason. ~$200 and a weekend
2001ATL
