Rear shock replacement how-to?
I read on this forum about a member drilling a hole thru the shock and twisting it with a screw driver while keeping the top nut locked. I don't have deep sockets so I was doing it with a monkey wrench... never again!
The rear left gave me so much trouble I was there for an hour cussing, the rear right one somehow went smoothly.
2002 4Runner new rear shocks with old bushing
Hello, I just replaced the rear shocks at the dealership but they reused the old bushing.
This was in the paper work "Replaced rear shocks, bushings were not in stock. Reused old bushings."
Should I ask the to install new bushings?
2002 4Runner SR5
I guess I'll chime in since I struggled with installing rear shocks. Taking my old ones out was easy because I used the suggestions I learned on the forum. I took the bottom bolts out first, grabbed onto the shock with a big channel locks, got a socket on the top nut and spun them out with relative ease.
I chose Bilstein replacements but they were a little different than OEM. You can tighten the top nut to a certain point but then the spindle starts spinning inside the shock. There's a allen head on the top of the spindle you can hold while you tighten the nut but now you can no longer use a socket. I was painfully using an open end wrench getting a minuscule turn over and over again until I finally got them tight. And this is all blind just feeling the wrench back onto the nut. What a pain! What would have been the ticket but I didn't own them at the time is those ratcheting wrenches. This way, I could have had the ratchet function and also be able to hold the shock spindle with the allen on top. After that experience, I bought a set of those ratcheting wrenches which come in very handy.
Hope this helps.
2002 4Runner SR5
they probably reused the uppers...i personally would want new ones there too, you could prob have them order new ones or bring new ones to them...should only take about 10 mins to install them since all the hard work is already done.
Hope this helps.
I recently replaced my shocks with Bilstien shocks, I too used an allen wrench in the top of the shock bolt but I had a ratcheting end wrench on the nut which made he job much easier. I had to use a sawzall to get one of the shocks out too, easy job.
I used the bending back and forth method to remove, but I took a little different approach to re-install. I cut a small section of the inner fender well out so I could get my hand in there for the top nut and bushings. This way it will be there for the next time.
Just replaced mine on the weekend, one shock wedged my socket and ratchet onto the top nut and turned the shock until it loosened off, the other I had to awkwardly cut away at bushing stud area until it fell apart. Good luck man
D'Angelo
